What does this mean? At first i thought it was the overall quality of the video, but then i thought it might be the quality of the picture when you search through the VCD,SVCD etc. So what does it mean?
Do you mean, the motion precision search option in video settings? Basically, it's a quality setting. You can adjust the amount of time your PC spends encoding your file. Fast action scenes tend to require the higher settings or the video becomes blocky/movement unsmooth. I've read that the norm. is to use 'normal' for VCD and 'highest setting' for SVCD due to the difference in quailty of the output media. I tend to use 'high quality (slow)' for VCD and get decent results.
Diamond Search for motion estimation
By bijo911 in forum ProgrammingReplies: 2Last Post: 10th May 2011, 18:26 -
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 10:40 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 15:30 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
