I have a DVD that's a little over 4.7GB and It has like 6 movie trailors and other junk in extras that I don't want.
Is there anyway I can copy the DVD and leave out those certain extras while still having the menues intact?
Results 1 to 9 of 9
Try ifoedit...
http://mpucoder.kewlhair.com/derrow/index.html -
Thanks but that site dos'ent show me how to do anything
Do you know of any sites that have auctual guides of how to do It....that are more suited to newbies like me? -
Woohoo!! I did It.I followed the directions as best possible in the guide below.After I played the movie in ifoedit and it told me what titles I played,It was kinda difficult though to figure out which files I was supposed to keep and which not too.
But I figured it out and then afterwards burned the DVD with nero.Everything plays great except for the extras which I cut out.Now whenever I have to split a DVD onto two DVD-R's I don't have to lose the cool menues
I did it! yay! *hop,skip,jump*
http://mpucoder.kewlhair.com/derrow/menuidiot.html -
easy.just run dvd decypter, this will show you the main movie files, just rip those n ignore the rest, but also remember to rip the first video ts vob,bup,ifo files as well..thats it...simple !
can u just rip all the movie files VTS_01_x, (Including the menus) and the video_ts and just burn them back to a dvdr? Or do you have to stip streams with Ifo Edit?
I.E.
i have
VTS_01_0 (Menu files)
VTS_01_x (Movie Files)
VIDEO_TS
just ripped straight from the DVD with nothing changed and burnt them back to DVDR would it work? -
Yeah..That should work..Thats what I do...
You must have
Video_ts.ifo
Video_ts.vob
Video_ts.bub
and then chuck in your Vts vob n ifo files.
This works ok in my Afreey dvd player but some other makes dont want to play it i think its because they have a look through the files n wont play it if it thinks something is missing (Nero does the same if you try to burn in DVD Video mode so use UDF/ISO instead.) -
Hey there,
I am trying to do the exact thing as stated above. Andydd, I was hoping you could lend a quick hand. I am pretty new at ripping dvds and the method I am using currently is not giving me .ac3 sound. I was hoping you could lay out step by step directions for me using dvd decryptor to rip only the main movie and main menu and then burn with Nero as UDF/ISO. Not sure what mode to have dvd decryptor in example ifo, file or something else. Thanks a bunch in advance.blindy
best softwareto burn raw mpgs with out haveing to rencodeing the video file
By mike300 in forum Authoring (DVD)Replies: 5Last Post: 22nd Aug 2010, 10:28 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 11:41 -
Converting a DVD to AVI with all menus intact
By beatsntoons in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2009, 15:39 -
Creating top level and sublevel DVD menues in PS 11+
By G16aByT3 in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2007, 10:06 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 14:02
