Hi: I currently use a Matrox Marvel for video capture but it has a non standard capture resolution of 704x576 (pal): so if I want to capture for DVD I have to resize the capture-which takes time. Will either the older (non radion) all in wonder 32 or the All in wonder VE capture in real time mpeg 2 at a resolution of 720x576? I ask about the older all in wonder because these are tuning up quite cheap
Are you saying I can use a 704x576 mpegs 2 for dvd? or that most authoring programs will convert it before creating the DVD
Cheers -
Hi,
I use an AIW 128pro w/32 meg on board. agp to capture all res. inc 720x576 for dvd quality with NO frame drops. (all scsi subsystem). Capture using MMC or Ulead DVD MovieFactory. Recommend using MMC7.5 or 7.6 and Stinky's reg tool to fine tune the settings.
They're a great card for the price and I've no reservations recommending them.
regards
daveg -
From DVD DemystifiedOriginally Posted by keithm
Allowable picture resolutions are:
MPEG-2, 525/60 (NTSC): 720x480, 704x480, 352x480
MPEG-2, 625/50 (PAL): 720x576, 704x576, 352x576
MPEG-1, 525/60 (NTSC): 352x240
MPEG-1, 625/50 (PAL): 352x288
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
A Few Questions About Older Sony "HD-ready" CRTs, I-Link, etc.
By Seeker47 in forum DVB / IPTVReplies: 5Last Post: 7th Jun 2010, 01:51 -
Need help RE: "stuttering" audio on older DV tapes during capture
By seaoharewhy in forum RestorationReplies: 9Last Post: 11th Apr 2008, 08:44 -
What is an "older" DVD player?
By lordsmurf in forum DVD & Blu-ray PlayersReplies: 8Last Post: 13th Jun 2007, 18:12
