i am trying to burn an avi movie using nero 5.5 but it says unsupported file format can anyone help
Don't use Nero to burn AVI's, most of the time it will give problems.
However your problem is a missing codec, download an install the Nimo Codec Pack, and that should cure the problem. There are a few other codec's about, like www.divx.com DivX 5.02 but mainly Nimo has all the rest.
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
Use TMPGEnc and a VCD template to make the mpeg's for Nero to burn -
What are you trying to burn? If it is a VCD, you avi file needs to be a MPEG-1, if a SVCD, it needs to be a MPEG-2.
http://www.vcdhelp.com/tmpgenc.htm
http://www.vcdhelp.com/tmpgencsvcd.htm
Hello.
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 10:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 12:56 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 13:54 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 12th Dec 2008, 00:13 -
Subtitled AVI Movie File - Can't Convert To DVD Format Without Glitches
By TheGimp in forum ffmpegX general discussionReplies: 13Last Post: 19th May 2008, 01:48
