I used to be able to open dat files in TMP and encode them, now it wont let me, I just get the "unsupported file can not open" message. I tried to use VCDGear to conver the dat to mpg, but when I open the converted mpg into TMP, TMP just hangs. Any ideas would be appreciated.thanks!
Results 1 to 9 of 9
Installed Divx 3, 4 and 5. Installed Nimo. Changed priority in TMP of Directshow, but still no luck. help please!
renaming to avi doesnt work.
rsuave..already tried vcdgear. read my first post.
any other ideas???? -
I have the same problem....please help......
My *.dat file only work on my VCD player...but it doesn't work on my computer.....I wonder if I convert *.dat to MPG it will work on my computer??? I use win 98.......thanks -
If it is from a VCD, just rename as .mpg, as they are just plain mpeg files.
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
.3GP File currupted o unsupported
By MikeDinner in forum EditingReplies: 2Last Post: 31st Mar 2009, 04:02 -
Restoring capture from Windows Movie Maker .tmp file
By markm96160 in forum Capturing and VCRReplies: 3Last Post: 17th Nov 2008, 14:37 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
