can anyone tell me what causes this and how to prevent it?
im using the latest verion of all software (tmpg,dvd2avi,smartripper)
and converting useing standard pal template
running a 1600+ processor with 512 meg of memory dont get it every time i convert but just on certain films anyone with any ideas please
If you are seeing horizontal stripes these are interlacing artifacts, OK for TV but ugly on PC. Read up on De-Interlacing or IVTC.
This will occur when you have selected the wrong "first field". Select the field other than the one that you did when you encoded and see if these lines go away.
tried reversing interlace setting and also changing the field order
still no change
this only appears to happen when ripping a dvdr any other ideas please -
What is your source (ie, interlaced or progressive)? Don't try to encode a progressive stream with interlaced settings.
Anyone know how to do this effect?
By bojadada in forum EditingReplies: 1Last Post: 17th Feb 2010, 00:31 -
what effect is this?
By daiweb in forum EditingReplies: 1Last Post: 7th Nov 2009, 16:19 -
x264 VAQ Blind Tests - Please vote
By Razorholt in forum Off topicReplies: 0Last Post: 11th Apr 2008, 23:02 -
Any good tools for color blind folks?
By binister in forum RestorationReplies: 1Last Post: 10th Jan 2008, 03:00 -
can DVD 9 cause DVD player spoiled/the dvd lens blind?
By C-W in forum MediaReplies: 1Last Post: 30th May 2007, 08:56
