  1. I have an AVI file that I can play in Windows Media Player, but that won't load into TMPGEnc. I've re-installed both DivX Codecs, and changed the priority of the AVI VFW Reader, but to no avail.
    How can I find out what compression is used on the AVI file?
    Cheers in advance,
    LittleCharva
  2. Banned
    Jun 2001
    UK
    You installed "Both" codec's ? there is more than 2, download and install the Nimo Codec Pack and that should cure the problem. There are a few other codec's about, like www.divx.com DivX 5.02 but mainly Nimo has all the rest.
    http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
    Load AVI into Vdub and select file > file information to see the video and audio codec's that are used
  3. Cheers, you are a star.
    LittleCharva
  4. Banned
    Jun 2001
    UK
    twinkle twinkle
