  1. Other than Nero can any other program make an XVCD.
    Can VCDEasy do it?
    If so can you give me a quick walk through or tips I need to know.
    Not only am I perfect but I'm Canadian too!
  2. The only time I made an xsvcd was by mistake I had captured a program in dvd pal about 4000 bitrate using WinDVR.
    The program I used to authorise was Ulead Movie factory.
    When I was using this to authorise it gives the choice DVD, VCD, SVCD
    I selected DVD, but the program told me I could not do it wrong MPEG dont know why, so I selected SVCD, it then told me the settings where too high for SVCD would I like to make an XSVCD clicked yes and it did it.
    Quality was very good hope this helps.
    Pothole.
  3. Does anyone one else if anything else can make an XVCD.
    I found out my DVD player can't play SVHS apparently but it can play XVCD up to 2500kbps so I just need to find a way to make it. Preferably with some freeware but I will buy something if I have to.
  4. I decided to try Ulead Movie factory. They ceratinly need anough patches to work in XP.
    But anyways I made my first XVCD and it works perfectly.
    Does anyone know where a good tutorial for this program is?
