I used DVD2AVI for conversion from .VOB to .D2V and .WAV files and tried to run TMEGnc but it stoped after 3% or 4% (second trial) of completion. I have PII500 machine with 128mb RAM. I've uninstalled and reinstalled the software. Haven't solved the problem. Please, help.
You should check and see if TMPGEnc stop always at the same frame which is given. Most probably you then have a bad frame. As you are encoding from a VOB I would suggest ripping the DVD again.
MKV stops
By kcmccombs in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 23:17 -
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 11:16 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26 -
.MP4 to .AVI Conversion Issues - Loss of Sound, Won't Run to Completion
By gumrunner505 in forum ffmpegX general discussionReplies: 1Last Post: 10th Oct 2007, 20:49
