I copied the files off a VCD straight to my hard drive...now i want to burn them again to a VCD .. they are to big for a standard CD ie over 700mb so how do i get these files onto another CD?
If you use Nero you can use the wizard to create a (S)VCD. That should let you burn like 800+ mb..
Also do a search on over burning..
But I'd use VCDEasy found in the tools menu.. It's easy and you can chapter and make stills..
Hope that helps -
Why not use Nero and do a "Disk To Disk" (Copy CD) copy, source and destination being the same drive. It will ask for the blank diskOriginally Posted by h0g4n
When doing it your way, for VCD's you only need the .dat file, which you can load back into any of the authoring programs to make a new VCD -
thanks guys
i tried to do a straight cd copy but it kept ******* up so i had to do it this way
Burnin DVD via Flick, all DVD clips come out pixilated towards end of disc?
By jacknscoob in forum Authoring (DVD)Replies: 27Last Post: 28th Jan 2012, 07:48 -
VCD with SWF files
By justdoit in forum Authoring (VCD/SVCD)Replies: 14Last Post: 28th Dec 2011, 21:45 -
burnin a 720p movie and playin it on PS3
By doodv1 in forum Video ConversionReplies: 2Last Post: 17th Jul 2010, 07:33 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
:?: DVD Burnin Question :?:
By marcelcukier in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2007, 09:59
