I converted my home videos to mpeg2 files using Pinnacle Studio 7. I burned the file using my DVD RAM/DVD-R to a DVD-R disk. I played the DVD-R disk in my DVD player Apex AD1500 but it only gives me an error message. In the User's manual of the Apex AD1500, it says it can play DVD, VCD, CD, and MP3. I don't see DVD-R. Could this be the reason why the player does not recognize the disk? What are other probable problems?
I had an Apex and had to return it for a player that will play the medium of discs that I wish to use in your case dvd-r I suggest when you go out to purchase a dvd player ask them to hook it up so you can test your movies any reputable dealer will do this. Good luck....
my apex1500 plays dvd-r, could it be the brand of media? or was it not burned compliant?
Andy -
My dad has an APEX 1500, I put the hack in for no Macro and region free and his still plays my DVD-R's, I use the Panasonic DMR-E20 to record them I use the following brands. All General Purpose 2.0.
Primedisc. - $1.60 each
CompUSA Brand - $3.99 each
TDK - $4.50 (on sale CompUSA)
All recorded in the 2 hour speed which is 5000 bitrate.
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 07:00 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 13:05 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33
