I have the ati multimedia center software installed....but I am having alot of problems with sound and picture. There is now a new beta for download and it seems to have the few fixes I am having trouble with under XP. The only problem is .....I cant seem to uninstall the old version. Its goes through the unstall process and says its completed doing the maintence but then still present.
I want to upgrade so I can see if thats the issue I am having....starting at groud zero. If anyone can assisnt in the uninstall of this ATI version 7.1 that would be awesome.
I tried reinstalling and uninstalling over and over...didnt seem to work..
Thanks!
look at google "alt.comp.periphs.videocards.ati" and search for "uninstall driver".
Next time you uninstall, delete the ATI folder, in your C: drive. You should also have an ATI install log, or .inf file in there. Delete that one, too. Then, reboot and install the new drivers.
Trouble with capture - ATI HD750/VDub
By TB Player in forum Capturing and VCRReplies: 10Last Post: 23rd Jan 2012, 17:37 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 10:41 -
Uninstall Office97 Problem
By bevills1 in forum ComputerReplies: 6Last Post: 26th Jun 2009, 15:39 -
i need a softwre that synchronization subtitles to mkv file?
By yigal33 in forum SubtitleReplies: 3Last Post: 5th Apr 2008, 06:38 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 15:09
