I have tryed the tryme version of MegaPEG, and exported a VCD very nicely, but couldnt find any support for a SVCD, although it does have MPEG2. Can 'Megapeg' do SVCD? I am considering buying the licenced version to remove the watermark. But first I would like to know what you recomend. Is the Panasonic better? Can it do SVCD? Price is not problem, so give me the best option. Where can I purchase the Panasonic plugin for AP online?
Thanks,
-hyper
You'll want Ligos LSX-LE, it's got SVCD-support and the quality is the best there is. It encodes directly from the timeline and manages to be 5 - 10 times faster than TMPG.
It creates also DVD-compliant files that SpruceUp eats without trouble and the quality is, you guessed, superb. -
Well, I've tried CCE and LSX. CCE is by far the FASTEST and it'll run you $2K (USD). However, in my experience of encoding, nothing touches TMPG for MPG2 encoding. (That is, beta 12a.) Yes, people have sent me their templates for CCE and LSX but I still couldn't get the same results as what TMPG would give me.
Best of all, TMPG is free! -
I use LSX Encoder 3.5. The difference I have found between it and Tmpgenc is at the same bitrates where Tmpgenc gets blocky, LSX doesn't get blocky but bands the colors (skies are a good example) I can deal with the color banding better than I can the blocks of Tmpgenc (not to mention some of the issues I have had when trying to edit the Tmpgenc created files, cutting, joining etc).
Michael
I would like to buy a VCR S-VHS Panasonic...can someone suggest me which of
By Giasan in forum RestorationReplies: 2Last Post: 12th Nov 2011, 17:50 -
I would like to buy one of these two VCR panasonic ...can someone suggest
By Giasan in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 11:41 -
Panasonic BDPS35 -Where to buy
By Armadeus in forum DVD & Blu-ray WritersReplies: 1Last Post: 17th Jan 2009, 23:02 -
Panasonic to buy Sanyo
By DereX888 in forum Latest Video NewsReplies: 4Last Post: 16th Nov 2008, 00:46 -
Panasonic AG 7350 UK service, DIY or buy another one?
By thegreatbear in forum RestorationReplies: 4Last Post: 26th Oct 2008, 13:00
