I am wondering if I can simply swap out the processor I have (AMD XP 1800+) for a 2200+, or will I have to get a new motherboard, etc?
I want to kick up my encoding time, and if I could just plug in a new processor, I will, but if I need a new mainbopard or need to redo the bios or something, I can't, I just don't have the skills.
Andy![]()
This crystal ball isn't working; I asked it what brand and model of motherboard you had, and it just didn't tell me. It did say that you ought to go to the motherboard manufacturer site and find out from the specs what processor speeds it supports, or look in the manual.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Hi,
Most of the mobo's that support an AMD 1800+ XP's will support the 2200+ as wel, but check the specs to be sure. Or check the bios if you can set it to the speed of the 2200+.
Hope this helps,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
It appears that you will need the latest BIOS update (unless you have it already, in which case you are good to go).
http://www.ecsusa.com/ecsusa/www.ecs.com.tw/download/k7sem.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
>>This crystal ball isn't working; I asked it what brand and model of motherboard you had, and it just didn't tell me......
Geez Mirror_Image...Maybe your crystal ball needs a bios upgrade???
.....Gotta love the crystal ball analogy
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Is it my processor?
By davej1983 in forum Software PlayingReplies: 7Last Post: 11th Jan 2009, 01:53 -
A question about Subtitle Processor
By tofuguy in forum SubtitleReplies: 2Last Post: 6th Oct 2008, 22:33 -
Question about how to replace internal hard drive
By jimdagys in forum ComputerReplies: 2Last Post: 21st Apr 2008, 11:22 -
Question re. DV Processor and IRE black
By nlec in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 9th Jun 2007, 03:31
