Is there a program to download to convert quiktime movies to mpeg...i just want to put videos on a cdr...thx
Make sure the HIGH QUALITY field is enable in both video and audio in your QT file. Then save the QT file before you start the compression. It works great in my case, DV -> iMovie -> QT -> VCD or SVCD.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
