Hi,
I ripped both disks of The Ten Commandments - both were larger than 4.3, so I used Rempeg to reduce the size. The first one imported ito Spruce (with the audio .ac3) with no problems at all. On the second one I keep getting the following message:
Temporal References in GOP #2 (Zero-based) are out of sequence (0xc106000a).
I tried both SMartripped and DVD Decrypter, demuxing to an .m2v file and then using REmpeg to reduce in size. I got the same error message both times. I use this procedure all the time and it has worked so far.
Any ideas what's wrong?
Thanks for any advice.
Deb
Results 1 to 1 of 1
temporal degrain
By unclescoob in forum RestorationReplies: 10Last Post: 3rd Mar 2012, 22:53 -
Mainboard cap replacement service references
By ranchhand in forum ComputerReplies: 6Last Post: 14th Jan 2012, 12:31 -
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)?!
By Bruxo in forum Authoring (DVD)Replies: 0Last Post: 27th Jan 2008, 21:34 -
temporal and spatial filtering
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2007, 10:23 -
Book or web references on computer programming for DVDs?
By newbee51 in forum ProgrammingReplies: 2Last Post: 30th May 2007, 19:09
