i bought an a04 (at least i think) and the first firmware flash i did gave me heaps of unintelligible errors... windows shows it as a pioneer 104 1.2.... i dont seem to be able to burn any video on it, or play any dvds... if ive stuffed my player is there any way i can fix it with another firmware update??? or should i just play stupid and return it to the place i bought it? only bought it 2 days ago
The 104 is the OEM version of the A04, so if you used an A04 firmware upgrade, then you should be OK. Just a thought, change the DMA mode to PIO mode in the OS you are using. For example, if the drive is on the Secondary IDE Channel as a Master, then you would open Device Manager and go to the Secondary Controller under IDE/ATAPI Controllers. Then double click the Secondary controller, and change the Master to PIO Mode only. If your config is different, change accordingly based on the example. Also, did it ever work?
just managed to get a dvd to play with the latest version of power dvd, still doesnt explain why i cant burn one tho
Originally Posted by aeon.Nemesis
What's wrong with this file?
By Khalua in forum Video ConversionReplies: 4Last Post: 3rd Sep 2011, 22:00 -
Optiarc DVD R AD7170A, flashed the drive, now only cd works
By Scottbj59 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Aug 2011, 12:36 -
Ive captured a good lossless AVI file, now what!
By Darkstraw in forum Video ConversionReplies: 3Last Post: 12th Aug 2008, 00:10 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 21:15 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 15:26
