I got film song vcds and I don't want to copy the entire vcd. Instead, I want to select the songs (tracks) from 2 or 3 vcds and to copy it in one vcd, which must be playable in vcd players. The vcds are in vcd 2 format. I don't know much technical things and can anyone help me to do this? Thanks.
You don't know about TMPGEnc ?, then you need to
Download it... http://www.tmpgenc.net/
Then insert one of your VCD's, copy the .dat file from it to your hard drive, it will be better to work with them this way rather that direct from the CD.
Now that you have the .dat file on your hard drive, load TMPGEnc and select File > Mpeg tools > Merge & Cut
Change the drop down arrow to MPEG 1 Video CD
Click the ADD button, in the file types change it to ALL Files (*.*) and browse and select the .dat file you copied to your hard drive
Next highlight the file that's in the white box and click Edit
Using the source range { = start } = end select the start and end of the part you want, and click OK
Use the Browse in the output, and select a location, and type in a name
Now Click Run
This will now make a mpeg 1 of the movie part you want, do the same for all the others you want.
When you have all the parts, you can either drop them into your authoring program one after another, or go back to TMPGEnc and select the Merge and cut again, this time drop all the files in by using the ADD.
TMPGEnc will join them all together for you.
need help selecting the right tool
By willymakit100 in forum Authoring (DVD)Replies: 3Last Post: 6th Jul 2011, 11:03 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Selecting audio/sub tracks when streaming to PS3
By Ronin Silfar in forum Software PlayingReplies: 2Last Post: 29th Jan 2010, 03:48 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 19:49 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 12:00
