When I goto VCD mode with Nero it doesn't have a time bar on the bottom but it has a Size Bar. When I load my VCD and go to burn it, it tells me that there is not enough space on my CD to hold the VCD even though I know that I have an 80 min CD-R and I encoded the VCD so that it is split. Can someone help me?
That is all.
It's bigger than 700 mb, but I never had a problem burning over 700 mb in the past.
That is all. -
Maybe its just a tad over the CD limit.
Different Blank CDs have different overburn sizes. I know my CDs (Verbatim 80min) can burn upto 85-87min or about 750mb but my CDRW has a limit on how much I can overburn, I found it to be 731mb.
Maybe your CDRW has a limit? Try cutting bout a minute off your mpg (1min = 10mb), keep cutting it until Nero allows you to burn the mpg.
Also the time bar in Nero is normal.
But if you already know your CDRW limit, try setting it permanently in Nero's options. *BEWARE* Nero or me holds no responsibilities if you try the overburn option and screw up your CDRW (Nero also mentions this)
Hope all this helps you. -
Its bigger that 700MbOriginally Posted by Happyman
1Gb is also bigger than 700Mb
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
