i loaded my vcd 1 of 3 of lord of the rings using tmpge and it worked fine and then burned using cd creator5 but it come out very dark and blurry is there a special way to format it before the burn or is there any tricks to getting it clear
You stated that "it" worked fine. Did you mean it encoded well? Did you view the movie before burning? If so, at what speed did you then burn your file?
Lord of the rings, originally 2 AVI's would make 3 CD's in VCD format, the movie is rather dark and you should have used TMPGEnc > setting > Advanced > Simple colour correctionOriginally Posted by jscott5150
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 16:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 09:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23
