I have ripped HPotter disc 2 and it will fit onto a DVDR no problem with no stripping. The problem I have is that when I burn it to a DVD-RW it works fine in my standalone, however, when I burn it to a DVD-R it freezes when you select the menu item.
Both discs were burned from the same image file (using IFOEDIT & ULEAD Movie Factory). The DVD-R is Datasafe Gen3 which work fine in my standalone for all my other rips (HPotter disc 1 was fine). It works ok in the PC. I tried another disc just incase I had a faulty one but same problem and another coaster for the collection !!
Any one else experienced this or have any suggestions.
Thanks.
I found I had to do that one with DVD-Decrypter.
Use ISO Read with 'Detect Mastering Errors' checked
Then ISO write.
Cheers .... -
Thanks. I'll give it a try - I think I used Smartripper on that one.
Harry Potter 6
By Drerunsit in forum Newbie / General discussionsReplies: 13Last Post: 17th Jun 2011, 12:23 -
Can't Rip Harry Potter Movies
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 16th Dec 2010, 06:06 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 08:45 -
Problem with Layer 1 & Harry Potter
By Jeptha in forum DVD RippingReplies: 0Last Post: 1st Sep 2010, 22:04 -
Download the Latest Harry Potter Movie: Legally!
By dvd3500 in forum Latest Video NewsReplies: 14Last Post: 26th Oct 2007, 12:53
