I have this avi file, that sometimes has color problems, it turns the picture from redish to normal and then back again many times during the movie. I also converted it to mpeg and then to VCD and it still does the same thing. What am i doing wrong? I researched the foroums and found that the Angel potion codec was bad. Which is a better codec? Divx?
Well once the original file is messed up, any conversion will only make things worse. You can try applying some filters, but if the original compression was bad, then you will continue to lose quality with each subsequent compression.
As for the best codec, depends what you want to do. For capturing its best to start with a lossless compression (like Huffy) if you have the hard drive space, as for the best codec that actually compresses your file, my vote would be Divx. -
I just downloaded Nimo, it claims it installs all the Divix packs as well from version 3 and up. What do you think of that?
Originally Posted by Trunks4191
http://www.vcdhelp.com/forum/viewtopic.php?t=108112
Editing HD video with E-AC-3 audio codec?
By calande in forum EditingReplies: 0Last Post: 23rd Jul 2011, 06:36 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
How to change audio codec in WMV video from WMA3 to WMA2?
By hanugro in forum AudioReplies: 6Last Post: 6th Dec 2009, 22:46 -
Audio codec problem in Any Video Converter
By robo5050 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 13:18 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03
