  1. please don't say "read the capture section" because it only confused me more. i just need a pci card that with capture from an analog camcorder to .avi format.
    thankyou
  2. This looks attractive to me:
    http://www.canopus.com/US/products/advc-50/pt_advc-50.asp
    But I'm not sure whether it will go to AVI or not. I saw the card in a computer shop today. It has a Philips encoder chip on it. So it will not be good to MPEG-1 as it is not a Winbond encoder chip.
  3. Almost good...
    Use the 50 for the low price...it has to be built in and needs an extra firewire card without a TI chipset.
    The (AVC?)- 100 is an external solution...same website..about $100,- more expensive, but worth it. Just connect it to a firewire card and it will convert anything (video/svideo/audio/pal/ntsc/secam) to and from DV over firewire. It also has a macrovision disabler (hidden feature).
    So.. Read the capture cards section for this device only.
    It's perfect for converting any old or new material to DV with a high to very high quality depending on the source.
    Nice about it, it needs no drivers, can also convert back to play/record on vcr/tv, probably disables macrovision copy protection and will work on any future computers and operating systems, since it won't need a driver.
    An other possibility is a standard TV card with a BT-8x8 chipset, it;s cheap, but you will get audio sync problems and not so good a video quality. It will take a lot more time to capture and create an end result. Price is lower though... See the PCTV from pinnacle for example.
    If you want ultra high quality, buy a PRO-ONE from pinnacle...but it will cost you at least $1000,- or more...for which you could buy a DVD burner also.
    For any questions...just reply.
    Greetz.
    Mar 2001
    Antwerp - Belgium (Europe
    I absolutely agree with this.
    Or think about the 'Matrox RT-2500', which is also of the same price-area of the Pro-One - if not, even cheaper, but captures (and exports!) analogue/DV to DV and DV to DV/analogue (the card has 2 IEEE1394 connectors on-board and a out-box via which analogue/SVideo can go in and out.
    Result : you can mix original DV and analogue together using Premiere.
    The card will convert the analogue to DV using an onboard codec.
    But enough about this commerce - I think it's up to you to decide which one or what to buy (it's your money and your quality )
  5. i'm just looking for something cheap (as i am new to this) that will produce decent quality like vhs or something.
  6. oh yeah, i'm wanting to use this for vcd's, not divx or anything.
  7. Again...
    If you want to try teh video thing, buy a tv-card...it will produce better then vhs quality (if source is better ofcourse) and probably will also filter macrovision. It's cheap $50,- to 80,- gives a lot of work, trial and error and probably audio sync problems on movies with long duration.
    If you want to do it right, buy a ADVC 50 for about € 199,- or 100 for about $299,-.. it will pay of on the end and save you a whole lot of time.
    But you'll have to spend some money to get it.
    Good luck.
