I have this avi file, that sometimes has color problems, it turns the picture from redish to normal and then back again many times during the movie. I also converted it to mpeg and then to VCD and it still does the same thing. What am i doing wrong? I researched the foroums and found that the Angel potion codec was bad. Which is a better codec? Divx?
Gab
If you have SMR (Angel portion) installed, get it off NOW !!
That will cause these problems, and you don't need it. Install the Nimo codec pack
PAL MPEG-2 to NTSC MPEG-2 - Different Color on TV
By HoosierGuy in forum Video ConversionReplies: 20Last Post: 5th Apr 2011, 13:43 -
Color Problems with Pinnacle Moviebox Ultimate
By fabitos in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 23:37 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Lg 42 lg 3000 color problems
By rambobambo in forum DVB / IPTVReplies: 3Last Post: 9th Oct 2008, 17:23 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 17:56
