Hi,
I followed the guide "The newbies guide to fitting a movie on one CD using TMPGEnc" (http://www.vcdhelp.com/forum/viewtopic.php?t=84759) to create the non-standard MPEG-1 clip. Just like to know what the max bit-rate I can set when using "2-pass VBR". In the guide, it says: "Maximum should be at least the standard which is 1150 for VCDs." Just like know what is the highest number I can use?
Thanks.
By definition, a non-standard Xvcd has no limitations. Whatever your target player or players will handle.
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 13:13 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
How to set optimal bitrate for MPEG
By peterbuilt in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2008, 11:13 -
What bitrate to rec standard VHS?
By jsmithepa in forum RestorationReplies: 31Last Post: 20th Jan 2008, 12:52 -
How to set bitrate in BeSweetGUI?
By ecc in forum AudioReplies: 4Last Post: 8th Nov 2007, 10:00
