I´m from Portugal and i have a problem or in decoding or in burning DVD to SVCD. I use Decrypter 3.1 and DVDx 1.5 and burn with Nero 5.5. My problem is when i play the SVCD and i want to go fwd, he goes, but when i continuos play, i lost the audio/video syncronisation. The audio start firts and then the video. I try to change several options, mas the result it's allways the same. Can anyone help me?
After I fast forward my VCDs I have to pause the video and then press play again to get the audio and video to sync up.
does the sync go out on both you PC and your DVD player, or just your DVD player?
if it just goes out on your dvd player, then it's prolly the shitty MPEG-1 decoder they put in there, i've seen a few dvd players like that, and all i can say is, try to take it back to where you got it from and get a refund. I have taken one back for my friend, it took a bit of convincing but when i started talking about bitrates and Motion Picture Encodeing Group(MPEG) he got confused(this was my plan) and gave me a refund.
but if it stuffes up on your DVD Player and on your PC. somthing went wrong with your encodeing, may i suggest check your settings and maybe try a new encodeing method.DVD to VCD made eazy
http://www.eazyvcd.tk
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
audio video out of sync - somewhat
By beetlespin in forum AudioReplies: 2Last Post: 18th Mar 2010, 23:51 -
Video Audio sync help
By carasy in forum Newbie / General discussionsReplies: 10Last Post: 19th Nov 2009, 20:09
