Hi,
i'm searching for a graphics card which is able to render in realtime to the Firewire-port. For example: Pic a video-file and play (convert) it in realtime to the Firewire-port without using Video-Editing Software.
Is something like this possible or available?
Tibby
Hi. Felt here as I’m looking for something similar, or a virtual driver that would emulate a second monitor, encode it thru software then pipe it thru the FireWire port of the pc.
I’m looking to record some vhs tape from the computer without a tv out. I have a dvd recorder that has a dv input which can translate dv to composite in real-time.. but i would like to be able to skip the pre encoding in dv format the files I wish to put on tape. -
Do you realize this thread is 18 years old? You probably should have just started a new thread.
Lots of old cheap graphics cards have s-video and composite out.
https://www.amazon.com/s?k=graphics+card+s-video
Long ago Matrox had the best composite and s-video output. Also, there are lots of inexpensive HDMI to s-video/composite converter boxes. I can't vouch for their quality.
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 16:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
What video card for realtime editing
By MI6 in forum EditingReplies: 0Last Post: 2nd Dec 2010, 03:47 -
need a new graphics card..
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2007, 01:50 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:19
