When I capture video with this card I get over 50% dropped
frames. Even when I try to capture 352*288 I get about 25% dropped frames. I have an Amd Duron 900mhz and 40g hd(dma 100,7200rpm) and 256mb ram(133mhz). If there is some way to capture without dropping frames I would like to know it.
AnonymousGuest
Hi. I've just bought a Pinnacle PCTV Rave card, and so far I've had no problems, just last night I captured an episode of the X-Files (42 min) with 6 dropped frames out of 68000.
Well, what kind of capturing program do you use and what video-codec?
(I used Virtual Dub 1.4c and the PicVideo 2.0 video codec!)
I suggest that you try that program and codec. If you already have tried, well....
Hope it works out!
/neXus
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38
