I have just created what a lot of people now seem to be reffering to as a DVD compliant CVD. My source is DV camcorder footage and once played back on my TV I was VERY pleased with the results. In fact after more than a year of playing around with VCD SVCD's formats etc. its the first time I have achieved what look like no compromise results.
I created the mpg by unlocking the tmpgenc SVCD template and simply changing the res to 352x576 and the audio to 48hz. This worked fine when played back on my Philips DVD701. However I am consious that I have not changed (reduced) the GOP settings to DVD limitations and may not have genuinely created an mpeg that can also be burnt on a DVD in the future (when they get cheaper blah blah blah).
So here's my question - should I use the SVCD template and change the GOP or use the tmgenc DVD(PAL) template and make the appropriate changes to bitrate/resoultion?
In theory, is the same mpeg 2 file with different headers. Those headers are determine the mpeg 2 to CVD/SVCD or DVD.
I prefer unlocking the SVCD template. I set the correct resolution for CVD and the audio to 44100 (which is the standard for CVD) or 48000 (which is not standard and some players are having problems)
Also, I set manual the correct GOP stracture (IBBPBBPBBPBBPBB for PAL) -
I have seen many posts similar to this. It begs the question whether CVDs are actually better quality than SVCDs ????? -
Quality is relative. Some may prefer the higher resolution of SVCD even if there are more artifacts. Technically an XSVCD at 720x480 should be far inferior to either a CVD or a SVCD at the same bitrate, since the bits per pixel is so much lower. However, the added sharpness may appeal more to some than others so no format can clearly be deemed as the highest quality.
I think the best way to look at it is to compare bits per pixel to resolution. According to the mpeg consortium 352x480 @ 2mbits is one of mpegs sweet spots. At this point you are achieving the optimum balance between bitrate and resolution. So at this bitrate or lower CVD makes more sense than SVCD. At a higher bitrate SVCD may be a more logical choice since the higher bitrate is enough to support the higher resolution, but again this is a subjective choice. -
SatStorm - thanks for the info. I seem to be able to get away with audio at 48000 on my Philips 701 player so I will stick with this. I think I will create a new template from the SVCD and change the GOP as per your post above. Thanks againfor your help - good info.
First time opening my DVD pixma i4500 - is there a dvd template for printin
By netrate in forum MediaReplies: 5Last Post: 14th Nov 2011, 09:06 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 08:55 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 13:13
