If you do, could you tell me how to set it up where it will roll over into a new cap once you hit the 2 or 4 GB limit? I can only get about 10 minutes of video captured before it shuts off saying I reached my limit. Someone mentioned that you could set it up to roll over once it hit the limit but I dont know where to find the options for it. If anyone could help, I would really appreciate it.
I know you can use Virtualdub to do it, but it wont seems to work on my PC for some reason...
Thanks...
Hello,
Try to capture with the little but very efficient soft AVI_IO.
This soft can chain your capture into multi avi files with NO AUDIO SYNC Problem.
But any way, the real solution to deal with this 4GB limit is to format a disk partition in NTFS (and then nomore limit ... but your disk space).
8)
Keshni. -
Thanks Keshni,
I'll check out AVI_IO. I wish that Vegas Video 3 did this though since that what I want to use.
I dont know much about formatting HD space. So I think I'll leave that option out.
I have two HD's in my PC. The second one is 30 GB with about 22 GB open. I dont know if I could even format to NTFS with that amount of space using WinME or not. Sounds like a mess to me!
Thanks though,
Chris -
I second what the other guy said about AVI_IO, which is excellent. That program is not free however, but there is a program called 'freeVCR' which you can download from here
http://freevcr.ifrance.com/freevcr/index-en.html
This can capture in segments very easily and simply. All the settings are displayed on one screen, with no menu's to scroll through. It can capture very well, keeping video and audio in sync for long periods of time. It has a few other good features, but suffice to say it is dead simple to use and very effective.
Cheers,
Ego
Thanks Ego!
Wow, so many progs out there to use! Hopefully I can find the right one.
I appreciate the info.
Chris
Using HD PVR Capture Module, then placing video in Sony Vegas....
By damonj_3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2011, 14:02 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 12:35 -
Can't capture video with Sony Vegas using my HP media center
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 10:45 -
Neither Vegas Video nor WinDV show dropped frames count after capture
By korey99 in forum Capturing and VCRReplies: 13Last Post: 9th Apr 2009, 17:25 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02
