Hello all,
I've tried to burn standard PAL VCDs which are about 791Mb and 79:22 minutes on to 80min/800Mb CDs but Nero 5.5.9.0 keeps saying not enough disk space and won't let me. Any idea why is that?
Even I set the Nero to overburn at 82mins, it still saying not enough
disk space. Are there any other software burner that are more flexible on overburning?
Hi There,
First of all set the Red maker in the General Tab to 85 then make sure that the Check For Correct Disc Format Before Burning is UNCHECKED.
Finally go into the Expert Features Tab and Check the Enable Overburn Disc-At-Once Burning and set the Maximum Cd Length 99-59-00 even if your writer doe's not support burning out to 99mins, then just click OK and your done.
This should sort out your problem when you burn the VCD nero will popup a window, just click on the Disc-At-Once option in the window and all being well it will burn it to CD.
PS: Just A Thought maybe your writer does not support overburning, so the above will test that as well.
Hope that helps ya
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 02:54 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 10:08 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
