i am using tmpgenc 2.53 to try and convert some avi files to vcd, but every time i try and convert the avi, the audio is fine, but there is just a black screen and no picture?!?!?!?
I have tried a program called AVI2VCD, which converts it fine, so why is tmpgenc not working?
any help would be greatly appreciated
thanks
When Hell is full, the Dead will walk the Earth
1, Make sure you have the codec's download and install the Nimo codec pack
2,
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4 -
thanks kingjohn, it seems to have done the trick.
Having trouble using DVDx to rip to .mpg or .avi
By waldothewonderboy in forum DVD RippingReplies: 19Last Post: 30th Aug 2010, 04:48 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 07:10 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
