Hi guys,
If I have Nimo codec pack installed I cant burn any VCD's using Nero 5.5.9 or Easy CD Creator 5 Platinum. If codec pack is uninstalled then Its no problem. The only reason I installed Nimo is because I had a xvid movie & could not play the audio without it. I also have the xvid codec installed. Any ideas anyone??
Results 1 to 12 of 12
What has a codec got to do with burning a disk ?
If your using those programs to convert the AVI to mpeg "Don’t"
Use TMPGEnc for all AVI to mpeg conversions -
What I mean is if the Nimo codec pack is installed at the same time as burning the burning software will not work. For instance I have already converted the file into mpg using TMPGenc, but when you add the file for burning using either Nero of ECD5 platinum the software crashes. If I uninstall Nimo everything is fine.
Did you load a template in TMPGEnc, what I am saying is that the codec's are not used when "Burning a disk" only when an AVI is used and the program would need to use them to decompress.
Where I walk, I walk alone. Where I fight, I fight alone.
I have had the same problem when i was trying to turn a avi to a mpg
tmpge it wouldnt work untill i took off the nimo pack -
I have ECD5 and the Nimo codec pack and no trouble at all. What I would suggest is you only choose to install the items you need from it. I only install 3 or 4 codecs and not all the other crap it had as those other things could indeed mess up another program.
Not only am I perfect but I'm Canadian too! -
Originally Posted by Happyman
Nimo already has that codec anyway
The New XviD Codec 28/06/02 + MiniCalc and AviC (FourCC Changer)
Problem with Media Player Codec Pack
By brassplyer in forum Software PlayingReplies: 3Last Post: 12th Jan 2012, 06:39 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
MEncoder Crash on WMV & Possible Codec Problem!?!?
By gonwk in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 19:15 -
Video editing & burning software
By katz68 in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 15:58 -
Codec problem (maybe) -- Hauppauge & nanoPEG editor
By SpaceCowboy9 in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2008, 10:49
