Fairly simple and stupid(i would imagine) but...
What's the difference?
You mean, dual layer DVDs? It is pretty simple. Dual layer means more room is available on the disc and thus, more content. Dual layer discs are preferred over double-sided discs for obvious reasons... (you don't have to flip the disc)
Not sure on that one. I haven't picked up a DVD writer yet, so I haven't kept up on things. I'm not certain if dual layer stuff (writers or media) is available to "the public" yet. But I could be wrong.
ok thank you
I don't have a DVD writer either yet but i was wondering if its possible to write on a DVD-r(w) with just a cd writer ? -
Erhm, nope.
A Single layer DVD only means that there is only one layer on the dvd. it should be able to contain about 4.7 gig. If you have a dual layered dvd, you can just fit 9.4 gig on it. DVD recorders do NOT support dual layer DVD recording (yet!). Playback should work fine on every DVD player.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success !
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Single Layer VS Double Layer, is one "better"?
By mjvgiese in forum MediaReplies: 4Last Post: 17th Feb 2010, 17:21 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 11:27 -
Encoding in 720p to single or double-layer DVDs?
By broaddd in forum Blu-ray RippingReplies: 2Last Post: 11th Feb 2009, 23:41
