I cannot play DivX files. Whatever player I used I always get grey screen but the sound is there. Can someone please help me? Everything worked OK couple of days ago...
Results 1 to 13 of 13
This didn't fix the problem. Still whenever I play DivX files i get a grey screen with sound...
Hi,
If you didn't already, try to install the DivX v3.11 codec. This one works the best and should work.
Also, is it only DivX that won't play, or other files aswell ??
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
I tried all sorts of players but I always end up with grey screen. I got DivX v.311 codec installed, I tried re-installing but nothing. It happens to all DivX files, not just one...
Maybe your source file sucks? Have you tried playing something else?
No, everything worked OK before I installed that little prog. called DivX plus that allows you to play DivX files through Hollywood + card... That prog. didnt work so I played DivX through BSPlayer and found out that I couldnt play DivX anymore (just grey screen and sound).
Are you sure the drivers for your video card are still intact? Maybe they got corrupted.
I tried uninstalling the drivers and then installing them again but no luck...this is a X-Files case
Grey screen, eh?
I fixed it a while ago. Open your movie-file with your windows media player (6.4 or later), right-click on the filename, chose properties, find the div-x tab or option, and slide the bars to for example 50. Somehow during installation the codec switched all brightness, colour etc to 0. Weird. Hope this works for you.
playing divx files
By manu4ever in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2009, 08:10 -
problem with playing divx files on sony NS67P ?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Feb 2008, 07:57 -
playing divx files
By avo_aj in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 05:23 -
playing divx files
By zinc in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Aug 2007, 05:50 -
.divx with subtiltle playing problem
By qknet in forum Software PlayingReplies: 6Last Post: 24th May 2007, 03:05
