I have been looking for some dvd help all over the net. I hope my search has ended here. How many people are acutally making backups of there dvd's instead of making 2 disc svcd's?? I am trying to backup my copy of Resident Evil to a dvd-r. I have ripped the entire cd using smart ripper. I have ripped the audio and video that I want. It will fit on a dvd-r with out re-encoding. My problem is that the vts_01_1.vob is not needed. (it does not contain any of the movie that I wan) It is like 800 meg or so. I tried burning with nero and prassi, but it will not let me cause it needs this file. So I put in a dummy file with that name. This did not work also. Do I need to edit my ifo files so that it reads the correct size?
TooHuge
i think you only need like the video_ts files and the vts_01_0 files. you shouldn't need the vts_01_1 files so you can take those out and then "get vts sectors" so that you dont' get any illegal navigation errors. after that, you should be okay i think.
Go here : http://mpucoder.kewlhair.com/derrow/index.html
Get IFOEDIT. Read the tutorials at the bottom.
Also try the doom9 tutorial for more info:
http://www.doom9.org/mpg/ifoedit-basic.htm
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00
