I'll admit I haven't checked ALL the posts, but my question is... can I use CCE to create DVD compatible mpegs? I know it has an option for DVD compliant, but does it really work?
I ask because I'm thinking of getting a DVD-R drive & am wondering what I'll need to create the files needed to make a DVD compatable mpeg.
TMPGEnc makes DVD compatible files, and the are a few sites that have extra templates if the packaged ones do not work for you.
Hello. -
Thanks for the reply, but you didn't answer my question. Can I use the DVD compliant option & ACTUALLY make DVD compliant MPEG2 files?
I don't use TMPGEnc. Tried it, been there, done it, don't like it.
I do use it for other purposes, but not for actual encoding of DVD "rips". -
Absolutely - do it all the time. However, I do my own menus and such - have not yet figured out how to use CCE to reencode "in place" - but I think the guides have that information.
You don't really need the "DVD compliant" checkbox in CCE - from what I understand, all that does is force the video size to 720 x 480, but it's normally already that (or even 352 x 480 for me, sometimes), so I normally don't bother to check it. -
Thanks VidGuy (been a while!). I thought so, but just wanted to check beforehand.
BD (AVC) to SD DVD NTSC with CCE
By stanley_a in forum Video ConversionReplies: 7Last Post: 28th Oct 2010, 12:04 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 19:15 -
DVD-RB with CCE taking 18 hours...
By hiimbored in forum DVD RippingReplies: 2Last Post: 23rd Nov 2008, 16:03 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
