  1. is there a another program that can capture directly to mpeg/mpeg2 other than videostudio 6, with a firewire and digital camcorder?
    because whenever i use vs6 the mpegs look wavy.
    also any suggestions for capturing live concert video with vs6?
    thank you
    Aug 2002
    stockton,ca
    try ulead dvd movie factory demo
    Jul 2001
    Maryland
    How do i get these programs to capture to MPEG?
    ALl it wants to do is capture firewire to DV codec.
    Mar 2001
    Antwerp - Belgium (Europe
    I think it's the Dazzle DV-Raptor, that has a seperate MPeG-2 add-on board (buyable seperately and connectable directly to the card, so you don't loose a 2nd PCI-slot).
    This card captures FireWire. Using the add-on card you'll be able to directly capture using a MPeG-coded (hardware encoded : always better than any software codec while you won't loose costly CPU-time for the encoding).
    Otherwise you need to go to the semi-professional area : the 'Matrox RT-family (like RT-2500)' also capture FireWire directly to MPeG-2 (I-frames only) using Premiere.
    btw. This codec seems to be only suitable for DVD as your final solution and not usable when you want to create (S)VCD.
  5. A simple program to us is Pinnacle Studio Ver 7 with good results. Also, a new version is available. Ulead is another good program that captures, encodes and burns video CD's.
