another vcd, this time got files inside the mpeg folder. but when i try to play them, it doesn't work. The program said there is some problem with either the program or the files itself. anybody can help me out? thnx!
If you have a VCD you should have a MPEGAV directory not a MPEG directory and your mpg files should have been converted to dat files.
WinFF 1.40 portable doesn't save folder options
By jgg in forum Video ConversionReplies: 2Last Post: 19th Jun 2012, 14:53 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 14:36 -
Video TS folder doesn't show up after DL.
By crowheart in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2007, 10:56
