  1. i was wondering is their anyway to tell this program where to go after a clip plays?
    What happens is i have one menu page now (part of a larger project) which has 3 options on it (clips). What happens is whatever clip you select once it is done, instead of going back to the menu, it goes onto the next clip instead. Is their anyway to fix this either with the program itself or maybe doing something with the ifo file? thanks again, Could use the help asap
  2. nevermind i fixed the problem, once again it was right in front of me and i kept missing it--
