Hi ... I have gone through your faqs and fourms and am still having problems with multiplexing. I recorded a video 480x480 svcd standard from a camcorder that is 18:15 min and have a wav file with music/narration that is 18:15 as well. All I am trying to do is overwrite the the sound in the video with the new wav file that I have.
I do it with Tmpeg ... it says successful but when I try and play back the resulting mpg, it crashes mediaplayer after 2 seconds (the original plays back fine in mediaplayer and the wav file plays back fine). What am I doing wrong ?
BTW, I had to convert the wav to an mp3 (224 kbps) for the multiplex load audio function to recognize it. and I have tried both simple and regular multiplex and still get the same error.
I downloaded bbmpeg but how do I use it to do what I need to do ? Any help is greatly appreciated. Thanks.
Browse Video > mpeg
Browse audio > WAV
This will re-encode, but this is the most successful method. Even with the MP3 at 224, it may still not play on a DVD player, even if you did get it to join audio/video -
well ... I cant seem to be able to select a wav file under browse audio ?! I have tmpegPlus 2.57. Is there problems with that version ?
surprisingly, if I use vcdhelp (not nero) to record it onto cd, it plays back on my dvd player with the new music just fine ... it just crashes on mediaplayer on windows ! -
You do need to save out the WAV first for it to be available
This is the WAV file you browse forBTW, I had to convert the wav to an mp3 (224 kbps)
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 4th Dec 2012, 00:54 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 06:00 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 16:52 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
