I ripped a DVD to my hard drive...now i want to convert parts of it into mp3 (not the entire movie). What is th best way to go about this and with what tools? Thanks so much
I have never done this, but a simplistic approach would be to use Microsoft's Sound Recorder (comes with Winx9x, W2K, and XP). Just double click on the sound icon in the system tray (by the clock), and then under Options...Properties, select "Recording" under "Adjust volume for" (make sure that Wave/MP3 is checked off in the below list so that it will show it). This will take you to a screen where you can control the record volume levels for various devices, as well as select which device gets recorded. Select the Wave/MP3.
Now you just have to playback the DVD any way that you like (WinDVD, IFOEDIT, etc.) If you can hear the sound, then you can use Sound Recorder to record it. The sound clips will save as .wav's. Then use Lame to convert to .mp3 (search for Lame encoder and you will find it).
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Converting HD 60fps MOV files for vegas editting
By 41i3n777 in forum Video ConversionReplies: 4Last Post: 21st Dec 2009, 19:37 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
