i am burning KTV vcd.![]()
so i download and download and i want to burn it out vcd so i can sing with freind.. :P
1 vcd have about 18 track or so.
i use nero burner , iomega zip cd ( purposely burn at 4 x slow speed)
( it have burn proff also)
done buring. watch with computer, EVERTHING IS OK
than put in vcd player.
certain song is CHOPPY a bit.![]()
but some is not... i don know y![]()
first track, all perfect, 2nd track, choppy, 3rd track all perfect again.
i am starting to suspect the file have error..
but whenever i watch the cd with comptuer everthing is perfect..
WHY.. WHY WHY>. i go going crazy.. some one teach teach and save me.. please.
( may be becuase differnt file are in different format? and nero burner is good at some format. but not all?? any one know?)
PLEASE help me, or may be i shoud get a new burner? or use a different software?
ps. KTV are like MTV.. ( stand for karioke tv)
OH mY GOD>.
now i foudn out some track does not fit on the TV is is bigger than it should..
my god..
this happen on one of my vcd player.. but not all, yet the chppyness is there.....
my god.. i am tire...what is wrong...
some track are perfect some track are choppy..
.. so it mean.. it is not my HARE WARE that have problem.. right?
it must mean the soft ware.. or somthing -
i 've encountered the same problem with some music videos i've downloaded. to get the problem videos to play properly i've had to reencode them using tmpegec to ensure that they will be 100 % vcd standard.
so u are telling to re-encode every file there is before bruing.
and that is the saveest way? to go?
even though some file is already good.. but just encode it again.. just for the hack of it?
i really want to make it work man..
thank you for your quick reply. -
Maybe if you can just encode the ones that are giving you problems. Just a guest, hope it works
actually..
i tell u a new situation...
i have 1 protable vcd player (panasonic, kidn of old)
one vcd player (make in china brand) ( kind of old)
one dvd player (make in china brand) (okly new)
my vcd is a bit chopping in the vcd player.
but in the DVD player it work 99% good.
... well at least it is better than before...
recording tv show hellp
By tim37 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 25th Apr 2014, 21:07 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
