Hi there!
Look, I've got to convert dvd to vcd, but I can't rip(my hd is full). I tried dvd2mpg, but I have lots of problems with it.. What are my options(if there are any)?
Ripping directly from your DVD drive I would not advise as the drive would be under excessive use and run hot. The only way would be to partly rip the VOB's by using a VOB stripper (it makes new VOB's by deviding them into chapters, so that they are even smaller). The software is called vobutil.exe, but I can't remember where I got it from. If you want it, email me as I can send you it via email (347kb).
i found a s/w that makes all trasparently:
you put on the dvd and it produces the mpeg 1 file automatically in the vcd standard and with good quality.
look for it at this link http://go.to/doom9
bye -
Cant be done, must be ripped... DVDx does it all in one step, but quality sux.
Good luck!
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 00:17 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 22:09 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
