  1. hi was just wondering how i can get sound on the menus in spruce up any info would be gr888 thanks
  2. unfortuently you cannot make an audio menu in spruceup
  3. oh well never mind any ideas on a prog that u can use m2v and ac3 that will let u have music on the menus????
  4. dvd maestro,
    ulead, (file has to be put together though)
    sonic dvd its
    dvd fusion dvd wise
    the list goes on
  5. does ulead let u use m2v and ac3 as these r the only files i like to work with?
  6. no, Ulead needs them as a multiplexed file
  7. how can i do that then and does it still have 5.1 sound?
  8. import the clip but place it on the menus tab, no idea about 5.1 sound, but it does support ac3 2 channel so it should support the 5.1
