Hello
When I transfer the video from my DV camcorder (Panasonic nv-ds 15) to the PC via firewire, the transfered video is too dark in all programs (Premier, Windows movie maker etc). When I was using windows 98 SE I had solved this problem by turning up the brightness or gamma in my video card's settings (GeForce 2 MX/MX 400). But in winXP although the brightness is turning up in the desktop and screen, the window where the avi is beeing recorded stays the same. What can I do ? I playback the tape in TV and the video is OK. Only when it transfered in PC it is too dark. I also try to turn up the brightness of my camcorder's LCD screen but nothing. What can I do ? who can adjust the brightness ? Windows Media Player has itsown buttons, Premier doesn't. Plz help me , i have stoped a project becouse of this problem.
thanks
George
Athens - Greece
Results 1 to 14 of 14
Hello
What I have done when I had that problem is loaded the video under VirtualDub, in VrtualDub you can use FILTERS and one of the filters is Brightness correction, you could adjust the brightness there & then resave the file see what happens. Also I am sure you are aware that if you are watching the file in the PC you can adjust the brightness under Media Player.
HTH
Spooky -
If apply the brightness effect the clip will be more bright (I think..) . The problem is that now, when i playback the clip from my camcorder in TV (teste in 3 different TVs) it looks fine. So If I apply brightness effect it will be very bright.
As you said, Windows Media Player has a brigtnes control. This is exactly what i want. A way to give more light in capture and play windows without having to render my clip. Premier doesn't have such an option and I have stoped my project becouse I can not edit such a dark avi files. In win98 SE turning up the birghtness or gamma from my video card's settings both capture and play windows become more bright. In winXP these settings give more light to whole screen but these windows aren't affected. Any idea ? (I don't know the virtualdub, should I download it ?)
plz help
Hello
HTH
Spooky -
if you are using the detonator drivers (dont know but other drivers should be the same) then you can use the overlay controls in the video control panel.
open media player or something that uses overlay. then open the video control panel and the overlay controls will no longer be greyed out. you can then adjust your overlay so it is bright enough. -
I use the detonatorXP drivers. What is the overlay controls you are talking about ? Do you mean the settings of video card in Color Correction window ? (brightness contrast gama & active color channel) ???? If you mean this, this is what i mean. By changing this settings both capture and play window do not beeing affected in Premier. If you mean somthing else let me know.. plz give details. thanks. -
sorry for the long wait, im not home much recently.
yes, that is what I mean, but... no, color controls are for the entire display. the overlay controls (in the same place) are only for video overlay only. -
Under video capture properties there is a brightness control
Not only am I perfect but I'm Canadian too! -
ROBO1964 wrote : Under video capture properties there is a brightness control
_________________
You mean in Premier ? I can not find such a control. Plz give details, I really want this feature. I have stoped my project becouse of these dark avi files i can not edit. thanks -
I am not sure about Premier but I imagine it is somewhere as I have seen it in all the capture programs I have used. Normally under capture, then click video and there should be some setting selections. One will have brigtness as well as hue and such, all little sliders. It might be from the capture driver. I am using WDM drivers. I imagine all cards would have these adjustments as they are rather important.
ROBI1964 wrote : I am not sure about Premier but I imagine it is somewhere as I have seen it in all the capture programs I have used. Normally under capture, then click video and there should be some setting selections. One will have brigtness as well as hue and such, all little sliders. It might be from the capture driver. I am using WDM drivers. I imagine all cards would have these adjustments as they are rather important.
_________________
I have looked everywhere in Premier and I didn't find something.
My video card has brightness and gamma controls but do not affect the window where video is captured. I'm trying to finde a programm or a software (driver or whatever ..don't know) to adjust the brightness or gamma of the entire window where the movie is being captured. Any idea ? -
I told you where it is, if you cannot find it, then you never will and there is no other way to get overlay controls.Originally Posted by dark
look at this
http://download.nvidia.com/Windows/30.82/NVDisplayPropertiesGuide_3082.pdf
view it and go to page 122 -
Thats not what I do.
Try Vitual Dub
Click capture avi
Click Video
Click Source
Click Device Settings
There are all the sliders for adjusting Brightness and other settings. If it is there it will be somewhere in Premiere
Have you tried the help menu and searched for brightness?Not only am I perfect but I'm Canadian too! -
FiEND wrote : I told you where it is, if you cannot find it, then you never will and there is no other way to get overlay controls.
look at this
Thank you. This is exactly what I was looking for all these days. Unfortutanetly there is no gamma control, but brightness is good enough for me. Also I would like to ask. Do this settings affect the video (avi file) itself (when I export it or only the way I watch it in the screen ? (I suppose the second) -
no it doesnt affect your recording at all, it only affects the overlay on the screen, or what you see.
MiniDV capture too dark!
By johnb41 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 7th Feb 2010, 13:21 -
dark video during capture from MDV
By guppie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 16:52 -
wired case of mini dv capture too dark
By devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2009, 17:44 -
VHS to DVD conversion- capture is way too dark
By kzip in forum Capturing and VCRReplies: 11Last Post: 2nd May 2009, 22:39 -
HELP- MiniDV capture TOO DARK
By cheeverm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 27th Jun 2007, 14:03
