ok... i recently bought a dvd player... it however cannot play svcd. i followed the vcd header trick and on some discs it works great... but on a few discs that i have burned like halfway through the movie it will scramble and then freeze.. sometimes u can forward it past the scrambling/freezing other times it will jsut freeze totally where i cant forward.... i have loads of svcd movies on my hard drive and i wanna watch them on my dvd player..... how can i avoid this freezing scrambling??... ony other thing i can think of is if i somehow converted svcd to dvd ( get some use outta my dvd burner) this is the vcd header guide i used. http://www.geocities.com/newestmoviesencode/dvdvcd
i used isobuster and extracted the mpeg files from the .bin file then used the latest version of TMPGEnc to change the header... i also get a warning after i have converted the header.. saying that it may play stangley or something...... well the warning message was correct.. any ideas on how i can get it to convert the header so it wont freezeing when i am watching it or how can i convert svcd to dvd?? thanks
ps: i post a pic of the error message in a few mins
heres a link to the warning message i get... this is maybe the reason it scrambles then freezes in my dvd player...
http://www.btinternet.com/~dark.flare/tmpgenc.JPG
the only movie that works 100% sweet is monsers inc.... ice age cd 1 and 2 froze and we were soldiers cd 1 was great but cd 2 froze half way... wonder what it could be
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 09:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 21:07
