    Feb 2001
    Newport, UK
    I have a DVD filesystem (VIDEO_TS, IFO, BUP and VOB) which I want to burn.
    I have stripped out all off the Subtitles and left one of the soundtracks, but its still 4,499megs
    Idealy, I would like to remove the credits at the end of the movie, which means that it would probably fit.
    Is there any way to remove/crop the last 5 mins off of the movie? If so, how do I do this??
    Feb 2001
    Newport, UK
    Fixed it.. I used the feature under IFOEdit called 'split 2 to DVDRs'.
    However, I have since learned of a tool called 'VOBSplit' which will do what I need.
