if I got a text file, how to add it to .dat file?
The only way i know of adding text-file subtitles is with VirtualDub and the VobSub/TextSub filter plugin.
I'm pretty sure this won't work with a .dat file. You'll probably have to convert the .dat to an .avi or .mpg - maybe use VCDgear to do that.
What format is your text file? I think TextSub will take most common formats.
cheers,
mcdruid -
the best program i've used to create subtitles so far is:
SubRip: http://www.subrip.fr.st/
(although I've only used it to rip subtitles from .vob's - I'm not sure if you can author your own from scratch with it)
and a good program for editting all formats of subtitle files is:
Subtitle Workshop: http://usuarios.lycos.es/dekoin/english/news.html
give them a try.
PS. I think allenultra is trying to do chinese subtitles (according to his pm's) Does anyone know anything about this - 'cause I certianly don't!!
cheers,
mcdruid
How to add Vietnamese subtitle ??
By caube in forum SubtitleReplies: 31Last Post: 17th Jan 2011, 18:16 -
create/add subtitle
By akakiami in forum DVD RippingReplies: 1Last Post: 15th Aug 2008, 05:40 -
add a subtitle (.sup) to a mp4
By dmdevotee in forum SubtitleReplies: 6Last Post: 24th Jul 2008, 09:46 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37 -
How to add subtitle to a video
By Chuba753 in forum SubtitleReplies: 7Last Post: 7th Jun 2008, 22:31
