Hi there, I am trying to make a vcd using 90 min cds and nero is not
recognising that i have a 90min cd in the drive. I have changed the
preferences to read yellow marker 89mins and red marker 90mins.
I am using nero 5.5.9.0. If I go into medium info it says that their is only
703mb 79mins cd in the drive. But I am using a brand new 90min 800mb
cd. It also says when the screen asks for a cd with more space is
"the medium required for the compilation is CD-R/RW and medium type
in recorder is CD-R"
Please help!!!
Hi there, what you need to do is open up Nero (Standard Interface) and then click on FILE, PREFERENCES, EXPERT FEATURES and then check the option enable OVERBURN and set the maximum length of your disc to 99 mins.
Hope that helps!!
chrome ;0) -
Ok I have looked in there and changed the settings. but I am just a bit worried about the warning it says about overburning.
Will it damage my burner at all. -
Almost all recent burners support overburning to some degree. Just give it a try. Besides, CD writers come cheap these days!
Thanks for your help everyone.
I havent tried it as yet. Still a bit worried about damaging my burner. -
Don't worry Aussie
As long as you don't overburn 2min more than the CD, you'll be just fine. (EX: 90min overburn 92min) (80min overbunr 82min)
I personally overburn my 99min cd's to 101min all the time! -
If you want to know the true capacity of your CD, NERO has a utility to determine the total overburnability. I just set mine (90min) to 99 min and see how it actually stacks up. This way I was able to use my 90min CD's to record 96m33min33fr--No problems so far and you can get close to a gig on these
This also lets you adjust the yellow and red markers to more accurate settings.
Hi there aussie8964, make sure your CDRW can overburn, hey it's your drive and if its still cover by any warranty don't bother........let others experiment, they don't have to return the goods!!!
If you want some tips, then PM me and I will try to explain as best I can.
chrome ;0)
Trying to make bootable CDs / DVDs with ImgBurn
By Seeker47 in forum ComputerReplies: 2Last Post: 24th Apr 2011, 21:04 -
Need a free program to burn Music CDs and make all tracks the volume level
By Starry in forum AudioReplies: 5Last Post: 19th Mar 2011, 17:26 -
Nero works with CDs not with DVDs
By fiiido in forum DVD & Blu-ray WritersReplies: 13Last Post: 23rd May 2008, 04:44 -
How do i make restore cds for my dell 2400?
By f-zer0 in forum ComputerReplies: 8Last Post: 12th Jan 2008, 12:02 -
Will a DVD recorder make CDs too?
By upther in forum DVD & Blu-ray RecordersReplies: 9Last Post: 22nd Jun 2007, 01:57
